I'm guessing you're talking about in the house battery/hydraulic pump compartment.
One breaker should be for the hydraulic pump for the jacks and the other probably is for the inverter but I have not tripped either yet to learn for certain.
The other fuses are the ones wired hot to the house batteries? I, again, have not pulled each fuse to see what stops working but I'm guessing these:
Steps
Propane Leak Detector
Dash USB jacks
Radio memory when the radio is set to run from the house batteries instead of the chassis battery
No good guess on the fifth fuse, though.
Ray
2020 Georgetown GT5 34H5
