Compartment lock problem/replacement problem 2021 Georgetown 34 H5
My driver side compartment door just in front of rear wheels appears damaged. The door is locked (maybe someone wanted in) and the lock will not let the key go in. Problems are how do I get it open, where do I get a replacement tumbler or a new handle assembly required. After replacement how do I rekey so this compartment uses same key as all the other compartments? I am not sure but I think it’s a Lippert Slam door latch.
Also if someone has upgraded their compartment door locks, do you have one of the original equipment locks available? Thanks,
2021 Georgetown 34 H5.
