Day time running / clearance lights 08 34 ft Forest River Se
Day time running / clearance lights not working. Brake, turn and tail lights work. I have 5 fuses inside the motor home Ford fuse block( near emergency brake) that aren’t getting power. I’ve checking the wiring, swapped relays and all the big fuses in the engine compartment test working 12 volt load tester. Rear clearance lights had water in them. Dried them out and still no power? Any help appreciated.
FF
FF
