Old 07-27-2020, 09:17 AM   #1
Does the GT5 have a built-in trailer brake controller?
I have a 2017 GT31L5.
Does my GT have an electronic trailer brake controller or do I need to install one?
If I need to install one, what do I use and where does it install?
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 07-27-2020, 10:01 AM   #2
Iggy's Avatar
Most all F-53 Ford bare chassis have brake controller wiring.
So if you check the location I show below you will know for sure.
It does not have a Brake controller for a trailer but it is prewired for one.
You should have the plug and wires attached to he left side of the steering column under the dash.
f you buy the specific plug in harness with your brake controller it will feed all the way back to the 7 pin plug at the hitch.
Here is a link to the Brake Controller and cable for the Ford F-53 . Double check please.
https://www.etrailer.com/question-143906.html
I also found this picture of the location of the plug.
Old 07-27-2020, 10:12 AM   #3
Mr Towed's Avatar
If at all possible, use a factory made brake controller, they tend to be much more integrated into the vehicle than aftermarket versions are able to.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:15Nights
Mr Towed is offline   Reply With Quote
Old 07-27-2020, 10:17 AM   #4
Iggy's Avatar
This is a motorhome not a pickup truck.
Old 07-27-2020, 10:33 AM   #5
Commercial Member
I thought this might help as well just in case you need more info. Iggy has some great pics as well.
Cdefrees is offline   Reply With Quote
Old 07-27-2020, 10:38 AM   #6
NXR
NXR's Avatar
You might want to double-check things before you start. My buddy's 2019 GT5 had no 12 V power at the 7-pin connector. He took the connector apart, which is not easy, and found the 12 V wire was indeed present but had never been stripped and never connected to the connector pin.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 07-27-2020, 12:13 PM   #7
Mr Towed's Avatar
Understood, but being that it is a Ford chassis there may still be a factory brake controller that is intended for it. I donít know if thatís true for sure, but if there is then that is what I was recommending.
Old 07-27-2020, 06:19 PM   #8
Iggy's Avatar
Nope Ford doesn't have one for the F-53 chassis.
Only available is add-on Brake Controllers.
brake control, controller, trailer
