Originally Posted by campers302
Using Camco tie downs is much better because they drop into you awning groove and will not allow the awning to spin. No holes to drill. They are very simple and easy to use.
See my photo a couple posts back.(#15)
I'm using the claw mentioned by someone else at the base of each pole. They work well.
I disagree with hooking a strap to the tube.
I'm using brackets attached to the arm and use 'lashing' straps, NOT ratchet straps to tie down with.
If I need to put the awning away quickly, all I need to do is press the button on the lashing buckle, unhook the hook at the Claw and retract the awning. Nothing gets tangled in or wraps around the tube during retraction, the poles and straps (still attached at the top) simply lay back against the arms as the awning comes in.
I can release the straps and be retracting the awning in seconds if needed and deal with the straps and poles (if necessary) once the awning is safely retracted.
