Old 06-12-2021, 10:38 PM   #1
Dometic Fridge not powering on
My Dometic fridge isn’t turning on, I just installed new batteries and still not powering on. I checked all the fuses and all good. It’s like no power at all when I press the on button. Am I missing something? I checked the GFI also.
Thx in advance
Fidaddy is offline   Reply With Quote
Old 06-13-2021, 07:35 AM   #2
Which model fridge do you have?
Did you check the fuses on the board in the back of the fridge?
Have you tested for voltage to the fridge, both 12 volts and 120 volts?
Gotta go campin!
Old 06-13-2021, 01:13 PM   #3
Thx Bama,
Only thing I need the check is the Thermal fuse, all other fuses are good.
My model # RM3962
dometic, fridge, power
