Originally Posted by Jc4ut
Thinking of replacing mine but not sure how many lbs the strut should be.
That's not the only issue. The OEM struts are self-dampening, also. When you turn them loose, they spring open at first, then slowly complete the process ending with a soft, full extension. Using single function struts will result in doors springing open and violently snatching at their mountings if not held and controlled for their full travel.
