02-21-2018, 11:43 AM
Door will not latch closed in cold weather
I have an issue with my 2015 328 where when it is cold outside I cannot latch the door closed. In cold weather the door latch mechanism does not want to fit into the strike plate. As soon as the temperature warms up the door closes normally.
This is not a new issue for me, it has happened in the past, but since we try to stay in warm weather all of the time I don’t have to deal with it very often.
We are currently wintering in Yuma AZ. This morning the temperature dropped to 36 degrees and once again the door would not latch closed. The temperature has now risen to 45 degrees and the door does latch with some force. As soon as the temperature reaches 60 degrees I know the door will latch normally.
Just curious if any others have experienced this same issue and if so, where you able to correct the issue. For the life of me I cannot figure out why this happens and what adjustments to the door can be made.
Thanks,
rkulbok
(Ron & Karin)
2015 Georgetown 328TS
Full time since October 2015
02-21-2018, 12:15 PM
Location: Alberta - East of the Rockies, West of the Rest
Have you tried lubricating the latch mechanism with lithium grease?
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
02-21-2018, 12:26 PM
Try pushing in on the door from the outside. If it closes You may need to use a file on the receiver side of the latch.
02-21-2018, 04:35 PM
This has happened to me as well and I have adjusted and readjusted the strike plate to working conditions. Everything swells or contracts with varying temperature and humidity. I am in Yuma as well.
David
2015 GT 310 DS
2016 Ford Cmax Towed
02-21-2018, 07:05 PM
Kanadian Kamper
X2 on the lithium grease.
Then study up real close where the door meets the striker plate. Somebody is just out of alignment enough that the cold is causing some meter component to shrink enough to cause your trouble. Shouldn’t need to much adjustment by screw loosening and realignment or a little bit of filing.
Ken and Terry
02-21-2018, 07:13 PM
Scoundrel
Originally Posted by dfp
This has happened to me as well..... I am in Yuma as well.
Hmmmmmm.....
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
02-22-2018, 05:34 PM
Loose screws. I had 14 loose screws on my rig. Also had to lower the strike plate.
02-23-2018, 10:59 AM
I have seen doors on homes that need to have the strike plate adjuster twice a year
The front door on our home in the winter,,, the Dead Bolt does not line up right,,,
until Spring !!! Very glad that we do not use that door !!!
02-23-2018, 09:47 PM
Almost the same issue. 2018 Grey wolf 27RR. Door worked fine. Went to AZ in Oct. and the door would not latch. Did some adjustments and got it to latch. Upon returning to Ohio in Nov., I retuned it to the dealer for a correct adjustment. When it started to get colder, the door would pop open on its own. After popping open for several days, I used the dead bolt to keep it closed until spring for another trip to the dealer.
02-23-2018, 09:56 PM
OP leave us out to dry?
02-24-2018, 07:30 AM
Steelhorzz
Colder yet!
Just got back from a 2 week trip to the Midwest. We have a 2012 GT 360. The colder it got, (and we had many nights and days, in single digits), the harder it was to open and close both the door on the coach, and the basement compartments.
I adjusted the door latch a bit and it improved.
For the basement doors, I sprayed WD 40 in both the locks, and the latch mechanisms. They freed right up. Working well!! Probably have to shoot some lithium grease in them now that I'm back home in SoCal .
