09-16-2013, 12:19 PM
Drivers side and Pass side windows have faded
We have a 2005 Georgetown XL and the side Glass on Drivers side and the Passenger side have faded.....Looks like it could be a double pane glass and the material inside is faded........has anyone seen this problem...can it be repaired or do we have to replace the glass....makes it really hard to see out, especially in really sunny days.......
09-16-2013, 01:31 PM
Have same unit and no issues so far. The driver side is single pane glass in the drivers door that rolls up and down. Looks a lot like auto door glass. Passenger side is sliding windows. Never noticed if they were double pane.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
09-16-2013, 02:14 PM
Thanks to bend302 for reply
This pane may not be a double pane.....but We cannot figure out what has caused the window to darken......
09-16-2013, 02:18 PM
also do you ever dry Camp with your generator running at night........We get caught sometimes and have to Walmart camp and we have been running the generator at night.......but the Alarm went off last time...We have two detectors in bedroom area....one went off but the other did not......but it does bother me that the bedroom side is over the Gen. exhaust.......any Thoughts.
09-17-2013, 12:11 PM
A "Genturi" will usually solve that, but it's a PITA to set up in a Wal*Mart lot.
We use one whenever we dry camp to keep fumes out of the bedroom. Opening windows just makes it worse.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
09-17-2013, 12:18 PM
Thanks for reply,,,,,,,Question: What is a "Genturi" and PITA.......Again thanks for the info....
09-17-2013, 12:38 PM
A Genturi is a low-backpressure exhaust extension, either purchased from a camping supply store, or homemade.
A PITA is a Pain in the *****.
09-17-2013, 02:02 PM
Ok...I did a google search and I understand Gen-Turi....but my slide comes out over by genny exh pipe........any ideas on this.....unless We leave that slide in......
Also, looking at these.....will the air cond suck the fumes in......
We appreciate your comments as they are very helpfull....hope you do not tire of my questions.
09-17-2013, 03:46 PM
If you have the Onan 5500, you can safely extend the 1-1/4" exhaust up to three feet with e.m.t. Would that clear the slide?
Using the Genturi, I've never had the AC pull any fumes into the bedroom. Mine exhausts about two feet above the roof.
I made it with 3" thin wall PVC, some steel straps, some rivets, and a 90-degree e.m.t. sweep bend. I used two 2" suction cups and a home-made bracket to attach it. The only critical part is the measurement from the end of the e.m.t. to the base of the PVC. It should be the same as the i.d. of the PVC.
Cost less than $20.
09-17-2013, 06:14 PM
While I don't have a generator exhaust extension (Gen-turi) the folks who had my 2005 359ts had one and the brackets they installed are still there so I know one will fit your unit.
Actually, we never dry camp so it has not been an issue (yet). I would NOT run the generator and try to sleep above that exhaust. CO is lighter than air and will rise. I would lie awake all night waiting to be gassed!
Bill
10-09-2013, 08:58 AM
My GeorgeTown XL (2005) has some rocker switches on the dash with symbols that I cannot figure out what they do....I know (example) what the symbol for the Fog lights is, but a couple of the others are a mystery....any help.
10-09-2013, 09:10 AM
Can you post a picture. You can probably buff it out.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
10-09-2013, 12:37 PM
Here are my switches. Do you have similar?
10-09-2013, 01:05 PM
On the side panel you have:
Headlight Switch
ICC = Flashes your light to say thank you after someone flashes their lights to tell you it's okay to switch lanes
Batt Boost = You can use the coaches batteries to start your engine if your engine battery is too low
Fog Lights = Self explanatory
Mirror Heat = Heat for the mirrors
Mirror Remotes = Controls left and right mirrors
In the center console you have:
Dash Fan = Turns on the two fans on the windshield
Map Light = Turns on the passengers side map light
Radi0 = Turns on the radio when the engine is off
Generator = Turns on your generator
I think that covers it.
10-09-2013, 01:48 PM
This really helps.....Mine has the symbols but not the lettering.....Yours show what each is and has the lettering.....
wwaller
