Old 11-02-2020, 03:43 PM   #21
NXR
NXR's Avatar
Originally Posted by Btm View Post
All of this reminds me that I am growing old too soon and smart too late.
Likewise. It took me a year to figure that one out. <sigh>
I must have forgotten everything that the dealer did not teach me about that system.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 11-04-2020, 02:27 PM   #22
Just curious. The other Motorhomes you said you had. Did any of those have the Kitchen on the slide?
Akozub is offline   Reply With Quote
Old 11-04-2020, 02:40 PM   #23
NXR
NXR's Avatar
For the Georgetown, it depends on the model as to whether and where the e-chain is used.
The 34H5 has the kitchen in the slide but does not use the e-chain. Instead the wiring and piping slide in a slot on the rear side. The sofa/dinette is the only one of the three slides we have that uses the e-chain.
The 36B5, I think, uses the e-chain on the sofa/dinette slide, which is behind the driver, and also on the bunk bed slide but not the main bed slide. Its kitchen is not in a slide.
At least some earlier Georgetown models used hydraulic slide mechanisms. Perhaps someone with an earlier model could say how their electrical is moved around.
Ray
Old 11-04-2020, 02:54 PM   #24
Btm
My 31L5 has the sofa/dinette slide behind the driver and uses the E-chain immediately behind the driver.
Btm
Ben Moore
Temple,TX
2019 GT5 31L5F, 2014 Wrangler Unlimited
CHF rear, CHF front, Sumo springs front
Btm is offline   Reply With Quote
Old 11-04-2020, 05:37 PM   #25
rk06382's Avatar
My FR3 28DS has a kitchen stove on the slide. The e-chain is horizontal under the sink on the floor. Propane, 120v and 12v are inside the E-chain. The FR3 28DS kitchen slide is the same as the FR3 32DS.
Before I vacuumed the sawdust.
Name:	E-chain 1 20180619_174103.jpg
After I cleaned the area under the sink.
Name:	E-chain 2 20180620_173325.jpg
I cut a 1/4" sureply panel to reinforce the cabinet bottom.
Name:	E-chain 3 20180620_173434.jpg
After I replaced the original bottom panel.
Name:	E-chain 4 20180620_181016.jpg
These pictures were taken with the slide out in July 2017.
Robert
2018 FR3 28DS | Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 11-04-2020, 05:52 PM   #26
NXR
NXR's Avatar
Nice work. I'm guessing the kitchen slide is the the right of that cabinet?
Where does the furnace duct go underneath?
Ray
Old 11-04-2020, 06:30 PM   #27
rk06382's Avatar
Ray
Yes, I will attach the floorplan.
I found a picture from my PDI walk through. April 2017
Name:	FR3 kitchen 20170417_180054.jpg
The furnace is on the other side of the FR3 under the fridge. The duct goes underneath the floor from the furnace.
Robert
Old 11-04-2020, 11:53 PM   #28
Btm
Very good - much stronger than the original floor. The horizontal chain is much better than down a hole.
I had a 28DS and liked the size and layout with the separate shower. I would still have it , but after four ( 4 ) R R bearings going out before 13000 miles I had enough. Both inner and outer at the same time and galled so bad that they had to be torched off- leaving us stuck on the road for many hours.
Btm
Ben Moore
Temple,TX
Old 11-12-2020, 10:14 PM   #29
Btm
I have used my slide 3 times on this trip and no E-chain hang ups. The key retractor is working great.
Btm
Old 11-12-2020, 10:28 PM   #30
NXR
NXR's Avatar
So the extra tension was the key?
Ray
Old 11-13-2020, 09:34 AM   #31
Btm
Fix
Yes. The less than 8oz. of pull is all it took.
I believe the fix will last for a long time. The retractor chain is stainless, so no rust and it will never be used as much as it was designed for.
Easy fix-hardest part was attaching the retractor to the rear of the box.
The only must is attaching the E-chain a link or 2 in front of the retractor when the slide is out.
Btm
slide
