On of the compartments where the inverter is located is not well sealed, and water gets in, and the RV almost cut fire once. I am trying to find out the best way to seal it.
There is a seal, but obviously is not working well and I have to find a better solutions.
I made a small round hole on the site of the compartment to help air circulate, and I will probably put a small fan. But as for the seals around the compartment door, I need to make sure water (from water sprinklers or any water directed at the RV) won't penetrate it.
We thought we had a seal leak as water got in and fried our inverter. Turned out to be black tank sprayer nozzle was leaking directly above water heater and inverter every time I used it.
Same Here
__________________ 2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
