Originally Posted by Bayouownbeer
Does this emergency start switch in my coach it’s called battery boost have to be active for the alternator to charge the coach batteries going down the road?
No. The switch is only used when the chassis (engine) battery will not start the coach. The switch is held on while starting the engine and released when started. The start power comes from the coach batteries so the coach batteries must have enough charge in them to start the coach. The engine alternator will charge all the batteries if the coach batteries are not disconnected. If the coach batteries are disconnected they also will not be charged when connected to shore power. If the coach batteries are disconnected that will not prevent the emergence start switch from tying the batteries together, assuming the coach batteries are of sufficient charge. There is a fuse in the Battery Control Center (BCC) box that the emergency start switch input goes through to energize the interconnect relay for the emergency start and a fuse battery HOT output fuse. You should pull the cover off the BCC and check the fuses that are inside. What I have written here is assuming your power setup is like the standard FR Georgetown power distribution. Remember, for the emergency start function to work the coach batteries must be sufficiently charged. One other input; the battery disconnect switch at the steps is not powered by the chassis battery and if it is not working then your coach batteries may be depleted as to not allow switching.
