Old 09-12-2024, 11:19 AM   #1
Entry Door Strut Bracket type?
I have a 2021 GEORGETOWN 36K7. The door bracket for the strut broke. I can not find the part or a picture of the part that looks like mine. I am hoping someone out there can help me. I want to find the same bracket.
I have attached my picture of it.
Mr.GaryX is offline   Reply With Quote
Old 09-12-2024, 02:47 PM   #2
bikendan's Avatar
Moved thread from the Tech and Repair section to the Motorhome section's Georgetown sub-forum for better help from other Georgetown owners and possible factory support.
Old 09-12-2024, 03:48 PM   #3
cmulvey's Avatar
I don't have a picture of one but there is normally just a ball the is part of your mount (is apparently missing on yours.) The strut presses down over the ball.
Christian M
2021 Forest River Forester 3011DS
cmulvey is offline   Reply With Quote
Old 09-12-2024, 04:20 PM   #4
ForestGump34DS's Avatar
If you call FR with your VIN # they can point you in the right direction....I have the same bracket and it's on it's last leg too !!! Please post your info after talking to FR.....
Georgetown Parts
Kathy 574-206-7617
Georgetown Service and Warranty Center
574- 206-7600
2022 FR3 34DS
2021 FR Wildwood Lodge 42FK
2017 Thor Chateau 24B
ForestGump34DS is online now   Reply With Quote
Old 09-12-2024, 07:30 PM   #5
Strut Bracket
Hello, have you tried taking the bracket off and look where the ball stud used to be? You should be able to remove the remaining broken part, and screw in a new 10mm ball stud. Most auto part stores have them in stock or go with an online vendor. Usually cost around $6 for a two pack.
JoePK is offline   Reply With Quote
Old 09-12-2024, 07:35 PM   #6
NXR
NXR's Avatar
Great thought. Mine is really loose. Thanks!
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 09-13-2024, 08:43 AM   #7
realshelby's Avatar
Well, at least you have a supporting bracket. My '23 36D7 only has the ball studs going into the threshold and into bottom of door.
broke loose twice already.
I done what I can to reinforce the poor design and workmanship, but next up is a tether strap to limit how far it opens.
2023 GEORGETOWN 36D7
realshelby is offline   Reply With Quote
Old 09-13-2024, 12:34 PM   #8
David-NJ's Avatar
McMaster-Carr always a good source to find small parts. Use them all the time at work, sometimes they can be a bit pricey but usually have items in stock and can ship the same day.
https://www.mcmaster.com/products/~/...or+strut+mount
David
2023 Georgetown GT5 34H5
Towing: 2013 MINI Cooper S
David-NJ is offline   Reply With Quote
Old 09-13-2024, 12:36 PM   #9
NXR
NXR's Avatar
If you have about 8" between the upper set of hinges on the door and about 8" between the lower set of hinges on the door then consider using Lippert's friction hinges.
FR has changed the door a few times so I don't know what you have. At least a few people with a later GT7 had to drill out the rivets on an upper hinge and on a lower hinge and replace it with the friction hinges.
Ours just went between the two sets.
Ray
Old 09-16-2024, 06:25 AM   #10
Georgetown Parts
Kathy 574-206-7617
574- 206-7600
Thank you for the suggestion and the phone numbers. I will give them a call.
Old 09-16-2024, 06:28 AM   #11
It would be great if it is that easy! I will try to remove the bracket and see if it is a screw-in type or not.
Old 09-17-2024, 01:09 PM   #12
Don’t think so
I checked into this type and the ball a set to far back to work. You need one with the ball in the middle of the bracket because the ball is where the screw holes should be. The arm of the shock hits the door on the suggested part also
At least it won’t work in the 2022 36D7
And the screw holes don’t line up either on this suggested part
Jimbo
Jc4ut is offline   Reply With Quote
Old 09-18-2024, 08:03 AM   #13
realshelby's Avatar
Jimbo
My 36D7 does not have room for a bracket like pictured earlier either. In fact that problem is what made the strut fall off the second day I had mine home. It has no clearance, and hitting the door threshold plate tears it loose. I.....made more room for the strut head by peening down the threshold plate where it was going to rub.
Old 09-18-2024, 12:11 PM   #14
I removed the bracket and it just sits flat on the step. Then I thought I could drill a hole in the spot of the ball stud and get a long screw ball stud with a washer and screw it in from the underside. Unfortunately, the steps are blocking, and the thought of removing them to replace the ball stud does not sound worth it to me.
Thanks for the suggestion.
Old 09-19-2024, 09:28 AM   #15
Here you go:
https://www.amazon.com/Mounting-Brac.../dp/B08MWK6DBF
I suggest that you R&R the strut at the same time.
newer is offline   Reply With Quote
Old 09-19-2024, 07:48 PM   #16
Originally Posted by newer View Post
Here you go:
Like I stated these will not work. The 10mm ball stud HAS to be in the middle of the bracket otherwise the shock will hit the door. I tried!!!
And the bracket on the left in the picture sits up too high.
Jimbo
Old 09-21-2024, 10:02 AM   #17
Jimbo
I believe that it will work. You just have to relocate/move the mounting position vs using the original mounting holes that FR made/uses.
Otherwise you will have to contact FR and order them from their parts department if it is still available .
Old 10-01-2024, 04:48 PM   #18
Mr BB's Avatar
Gary; I found the manufacturer I also need the mount on the door.
https://www.hibshman.com/products maybe they will know more. I will try to call tomorrow
Bracket #169 for door I dont have # for one on coach
2020 Georgetown GT5 34M
2013 F150 Lariat eco
2016 Jeep Trailhawk (toad)
sold Reflection 297RSTS
Mr BB is offline   Reply With Quote
Old 10-02-2024, 11:44 AM   #19
Mr BB's Avatar
Stupid me I didnt see post 8 and 12 well any way found the one on the door
Anyway called and they do not deal directly to consumers but gave me the company that handles their brackets. here is the link for outside bracket
https://www.mcmaster.com/products/ba...l-length~0-78/ Around $22 with shipping
Billy
bracket, door
