Old 07-30-2021, 02:42 PM   #1
Fiberglass roof coating/sealant
What do y'all recommend for coating on my fiberglass roof? It's 8 years old and this year I can see the fiberglass somewhat glistening while on the roof.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 07-31-2021, 07:58 AM   #2
I have a 5 year old GT that is showing the same signs. I have wondered what would be best to use as well. On another thread someone uses a 3M fiberglass boat/RV wax. I have never tried it. Hope others have ideas for us.
yensidcamper is offline   Reply With Quote
Old 07-31-2021, 09:35 AM   #3
Here is a current thread on the irv2 forum you may find helpful.
https://www.irv2.com/forums/f258/cle...of-546994.html
2013 Itasca Ellipse 42QD
-2012 Lexington 265 GTS- Sold
Tow Vehicle 2017 GMC Acadia
clhjsh is offline   Reply With Quote
Old 07-31-2021, 09:49 AM   #4
don't put a wax on your roof you will need to walk on it to wash it no?
cfo111 is offline   Reply With Quote
Old 07-31-2021, 10:29 AM   #5
Dodge Guy's Avatar
Mine is 9 years old and still looks good, are you saying you are seeing the fibers coming through?
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 07-31-2021, 03:17 PM   #6
Yes, well sort of. I see the beginning of the glass fibers starting to glisten. Or show through
2008 Honda CR-V
Old 07-31-2021, 03:18 PM   #7
Thanks, I'll check it out.
2008 Honda CR-V
Old 07-31-2021, 03:44 PM   #8
NXR
NXR's Avatar
Not really a concern. The roof on ours is patterned and not smooth. I wax mine with a wax that has a UV protectant and it's not slippery at all.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 08-06-2021, 09:28 PM   #9
My Fiberglass roof was showing signs of severe degradation last winter, such that I had to cover it with a tarp to prevent water ingress. The fglass was cracked with a lot of short spider cracks which were only apparent when you looked at it with a magnifying glass. The roof is 10 yrs old.
I bit the bullet and ordered "Roof Magic" on line. It came as a 6 gallon kit and in the spring over 2 days I painted the roof. It looks great and there are no more leaks.
In my opinion, the fiberglass roof material is too thin and its just a question of when it will fail. I cleaned my roof every spring and kept up with the caulk, but the caulk did not fail, the fiberglass did.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
mogman is offline   Reply With Quote
Old 08-08-2021, 05:48 AM   #10
Ekw4156's Avatar
303, protects and shines
Ekw4156 is offline   Reply With Quote
fiberglass, roo, roof, seal
