Originally Posted by bclinton
Can you elaborate on "caulk the frame seam"?
Realizing that often window frames are different, on mine it was where the inner half of the frame joined the outer half. The window frame on mine was a two piece, one fitting in from the outside of the hole and mating with the inner trim piece which held it in place. There were little slots cut in the bottom of the frame that were supposed to drain any condensation out of the window frame but often allowed wind blown rain in.
Look for a seam on the inside of the window in the frame. If it isn't caulked I'd suggest adding some sealer to it so water that collects there doesn't leak into the wall. I used some black silicone sealer that I picked up at an Auto Parts store. To make sure it stuck good I wiped the seam down with some Acetone first. Stinks so use plenty of ventilation if you use it. It evaporates fast so the smell goes away fairly quickly.
Also, it may be possible that there is a leak above the window where roof and side meets. It could be anywhere along the length of the window and the window frame is channeling the water to one end where it's accumulating where the blistered area is.
Leaks are a real PITA to find.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
