Originally Posted by manvel
THANKS, for now I turn off the valve between tank and pump.The check valve in the pump must of went out.
You do not have a valve between the tank and pump.
That is your winterizing valve.
No not really.
Do this test first.
1. Disconnect water line from the campground.
2. Go inside and open the hot and cold water lines at the sink to remove any water pressure. You do not want water pump on while doing this.
After you have done this go out and turn on the campground water again.
Watch and see if your water tank level rises.
If it doesn't then yes the pumps back flow valve is stuck open with something and your tank will continue to fill up.
If the tank is not filling then you have reset the valve in the pump.
I have found that if you have city water hooked up and turn on your pump is when this valve gets stuck open.
Hope you are able to follow my steps.
