No need to level trailer to run the pump
The water pump is not dependent on the trailer being level only if yo are tyring to get the last couple gallons from it.
Reason for the pump not running:
1. No DC power to the trailer (battery or shore power/converter)
2. Switch not on. Mine has a light in the switch when on
3. Wires knocked off the pump or it's pressure limit switch
4. Blown fuse
5. Defective pump
6. If you have City water connected, the pressure in the line will cause the pump not to run. Open a tap to bleed pressure.
If you have a Volt-Ohm meter you can check for power at the pump when the pump switch is on. If power is there (fuse OK, switch on, power to the trailer) then the limit switch might be stick. A gentle tap may break it loose - GENTLE TAP.
Good luck.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
