Originally Posted by 43D18
But back to this water leak, I'm unclear how to determine the source of this leak.
Check the obvious first. Make sure the vent hose is connected properly to the tank on one end and usually the fill port on the other end.
Another possibility is a loose connection on the fill hose where it meets the tank.
Depending on how well covered your tank is, you may have to remove some panels. Another possibility is to use a flexible inspection "Scope" like those that are used to look inside walls by inspectors/contractors. You can often rent one. Fill the tank as full as you can and look into every space around the tank you can, paying close attention to any area where there is a connection. Just HOPE you don't have a hole in the tank caused by an errant drywall/sheet metal screw.
If I were a betting man I'd bet on one of the connections at the fill/vent area.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
