Originally Posted by Maxwell32
The pictures and platform look great wrapperman. Very creative idea. Any chance we could get the dimensions to help with the cutting?
I just used scrap wood I had lying around.
Platform size 38" X 32" X 5"
2 - 2" X 4" X 32"
Enough plywood to cover the top. I had 2 pieces of 3/4", 16" wide and 8' long. I cut the plywood into 2 pieces 16" wide by 38" long. That made my top. Then I cut 2 pieces 4" wide by 38" long for the bottom to keep the weight down. I also had 4 felt covered feet that are screw adjustable. I mounted them on the bottom so I could adjust the height of the platform.
Just measure the height of the refridge off of the floor. Mine was about 5.5" off of the floor which made the platform a perfect height.
After lowering the refridge it just rolled right on out onto the platform.
The reason 32" wide platform is because that was all the room I had in front of the refridge to the counter were the sink is. I have the 378 XL.
I had to take off the freezer door (simple 5 minute job and 1 refridge door).
If you have more room in front of the refridge I would recommend making your platform 48" wide so you could pull the refridge out 48" and I would think you could use 5/8" thick plywood.
Don't know why they couldn't have installed the refridge on the floor itself. But then again I don't build them, just buy them.
I plan on removing my refridge this week because the water is not dispensing from the door and it might be the water valve.
Good luck.
