Old 09-30-2022, 07:49 PM   #1
jwc55's Avatar
Front A/C is coming on with front furnace
Hello All
Just came back from a great trip in Michigan. The last night away was rather cool so we put the front furnace on to warm things up. The furnace came on like it should but so did the front A/C unit. Counterproductive to say the least. The same switch on the wall controls both the A/C and the furnace with a digital temperature setting. All units are Dometic in a 2015 Georgetown 377 XL. Bad or dirty connections at the wall switch, maybe. Any HVAC experts out there?
Jim & Millie
2015 Georgetown XL 377TS Ford F53
jwc55 is offline   Reply With Quote
Old 09-30-2022, 08:15 PM   #2
Mr. Dan's Avatar
If it’s the thermostat many of us have, the A/C compressor is not coming on - just the A/C blower. Cycle through mode and stop at Fan, use + or - key to cycle fan speed from HI or LO to AU for auto.
Old 09-30-2022, 08:19 PM   #3
jwc55's Avatar
Thanks Mr. Dan. I'll give that a try.
Jim & Millie
Old 10-01-2022, 12:11 AM   #4
My front A/C is a heat pump. It will try to heat up the RV and the propane furnace will kick on if necessary.
Dan_Frisbie is offline   Reply With Quote
Old 10-01-2022, 08:44 PM   #5
jwc55's Avatar
Thanks Mr. Dan
It was a perfect fix exactly as you described.
Jim & Millie
Old 10-02-2022, 12:39 AM   #6
LittleBill's Avatar
Originally Posted by jwc55 View Post
Thanks Mr. Dan
I have found that if you set the fan speed to a HI, MED or LO setting, the A/C unit will run continuously whether the furnace kicks in or not. This will just circulate the air in your unit and not engage your compressor like Mr. Dan already pointed out. So you need to set the fan to Auto and then the A/C blower won't run and the furnace blower will come when the furnace will actually be running.
If you have a Heat Pump then your thermostat probably has an Auto mode which will maintain a specific temperature (within a couple of degrees) using the A/C-HP unit based on whether you need to lower the temperature or raise it.
Good luck and be safe -
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
furnace
