Originally Posted by Nomore9-5
I'm going to come off looking cheap but I wonder about this. Since stopping your car tends to wear out front brakes much more quickly than back brakes there is a school of thought that back brakes are done every other time as fronts need to be done.
So I'm wondering if any motorhome owner/ back yard mechanics time their back brakes this way as well.
The factory OEM pads wear out at almost the same rate however the back wear just a little faster. So If the Front needs them then the backs are 100% ready to be serviced.
I purchased our MH New, I just did Front and Rear brakes @ 53,200 miles.
On our 2013 it is the same Part number for the Front and Rear pads.
I purchased from the FORD dealer because I wanted factory OEM Ford Pads.
I have not found any aftermarket pads that will last as long as OEM without killing the rotors.
fyi... The rotors are really costly and while ceramic pads will last longer they wear out the rotors faster. So for me factory OEM pads are for me.
