07-16-2021, 10:56 AM
Front windshield electric curtain
Looking for sources to replace the electric motor on my windshield electric shade! 2015 Georgetown 378XL. Looking for manufacturer.
07-16-2021, 01:28 PM
Senior Member - Retired
Your front motorized shade and rear day/night shades may be manufactured by Irvine Shade and Door.
If so, you are in luck as they have great customer service and have replacement parts. In my case they sent several new brackets at no charge.
Irvine Shade and Door, Inc
(574) 522-1446 (Phone)
(574) 522-0568 (Fax)
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
08-15-2021, 09:54 PM
They may have great customer service but their product is sketchy. We have to replace our motorized shade for a second time, and it does not get heavy use. Unfortunately, this seems to happen when we are parked for the night, get buckled in the next morning and find there is no power to the shade.
08-17-2021, 08:31 PM
I have 2013 Georgetown 378 xl and had my curtain motor stop working , I discovered a manufacturer design flaw , and fixed it myself. The edge of the curtain was cutting into the motor wire when ever it went up or down because the wire had no grove to go through on the bracket , so I grinder a grove and repaired the cut wire , problem solved . Maybe you have same issue, I will send before and after pictures, good luck
08-17-2021, 08:40 PM
08-18-2021, 01:38 PM
It's been a while since I looked at mine, but I do NOT recall the wire like that. Yours may be mis assembled nd possibly come out of the center hole vs having to cut a slot. Again, mine is fine and I do not recall the wire being like that - sorry i don't take apart working items on an RV.
08-18-2021, 04:01 PM
Our shade had the exact same problem. When taken apart to replace the motor, the wires were frayed. This is likely the issue a second time. We can’t look at it until we return home, so no privacy at night for now. It’s obviously a design flaw.
08-18-2021, 06:00 PM
I'll say it again (last time). Probably 50-75+% of the problems I have seen/heard over the 4 years i have had the misfortune to be involved in the RV community dealing with problems, most appear to be assembly problems vs actual product defects. That is the RV manufacturer's fault/problem, not the subassembly manufacturer providing a defective product. Then there are scenarios like the 10-20,000 Dometic AC defects or the Battery Control centers that happen too. But then when that defect is replaced, the problem is at least gone - usually.
08-24-2021, 10:40 AM
Another one here with that exact problem. In my case the wire was cut thru right at the motor with not enough left to splice. Ordered a replacement. Hardest part was taking the curtain down but I made sure the wires were routed properly when I put it back together.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
09-02-2021, 06:15 PM
I contacted Forest River and they sent me a new one for free. At the time it was 7 years old. Definitely a design flaw. They asked me to send the pictures and as soon as they saw it they sent me a new one right away. I also have a 378. Hope hat helps
2011 Gergetown 378 TS XL on a Workhorse W22 chassis
Toad is a 2014 Chevy Cruze RS
