In the rear storage compartment where the shoreline power cord and power center is, there is an outlet that is wired all the way forward to the coach batteries. It is a Furrion Solar Charge outlet. I have mounted and plugged in the solar panel charge controller to the outlet. I briefly had battery connection showing.
I had a wrong combination of male/female connectors to the solar panels. I may have shorted wires while plugging them in, although I did not see any sparks, etc.
When I went to check status of charge controller, there was no longer 12 volts coming in from the outlet. No power there at all.
Does anybody know how that outlet is actually connected to batteries? And where a fuse might be?
Thanks.
