Originally Posted by jdhoward
Shorted out(blew fuse) while attempting to add under cabinet lights by feeding off light over table in slide out . Fuse box by brake pedal all fuses ok. Could it be another location or inline. Can’t locate fuse. Any suggestions
We have a FR3 34DS, but I'm assuming the layout is similar. Do you know where all your AC breakers are ? The 12vdc fuses should be right next to them. In our case, it's in the rear driver's side, right above the power bay (where your 50 amp service cord is located).
The fuses by the break pedal are for the F-53 portion of your coach....
Good luck !!!
