Originally Posted by Truckdogg4
I have a 2016 Georgetown GT3 (30x3). The A/C and the 110 outlet plugs are not working. Everything else is working. Any ideas. Checked all the beakers under the bed and they were not tripped.
Are you plugged into shore power or using a generator, in order to get 120 volt AC power?
The Air Conditioner, outlets, and microwave work off of 120 volt AC power. Most everything else works off 12 volt DC, which can be provided by your battery when not connected to shore power or a generator.
Have you verified the shore power has power, and/or if you are using a generator, does your MH have an automatic transfer switch that switches between which source of 120 volt AC you are using (Shore power vs generator)?
