Old 06-06-2021, 12:30 PM   #1
Generator not providing house power
2016 Georgetown 30x3. When plugged into shore power, I have electricity. All breakers under be look good. Generator runs fine, breaker on generator on position . When I try to power from generator I have no power to house. Can someone point me in a direction from generator to house plug? Is there another breaker or fuse?
aerojet001 is offline   Reply With Quote
Old 06-06-2021, 01:03 PM   #2
bubbles's Avatar
I'm not familiar with your GT and don't know if ant GT's have it but in your power cable bay is there a receptacle to plug the shore cable into for the genny to power the coach?
Old 06-06-2021, 03:26 PM   #3
bubbles's Avatar
So, is this applicable or does your unit have an ATS (automatic transfer switch)?
Old 06-06-2021, 03:48 PM   #4
Did you plug you plug into plug inside of compartment if so check your genny body it also has breakers on it.
cfo111 is offline   Reply With Quote
Old 06-06-2021, 04:28 PM   #5
There is a receptacle that I plug shore power cable into. I have done this and motor home not getting the power.
Old 06-06-2021, 04:30 PM   #6
Only found one breaker on generator to the right of start switch. It is in correct position. Is there another I may have not found?
Old 06-06-2021, 04:31 PM   #7
Not sure if applicable? Where would I find?
Old 06-06-2021, 04:57 PM   #8
Look on genny there is a breaker like you have on your home reset it. If and when you find pust it the other way it is there look for it.
Old 06-06-2021, 05:18 PM   #9
NXR
NXR's Avatar
What make and model of generator do you have?
BTW, did you work for Aerojet? I used to work for GenCorp and have been to Sacramento for Six Sigma training. At the end of the last century.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 06-06-2021, 07:41 PM   #10
if you found the switch flip it the other way see what happens
Old 06-06-2021, 09:56 PM   #11
MNtraveler's Avatar
Do the same with the main 30 or 50 amp breaker inside the coach. Turn it fully off then fully on again. But if you did trip a breaker and it keeps tripping, then investigate further.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 06-07-2021, 05:59 PM   #12
Dennis King's Avatar
No Power From Generator
It is probably something very simple.
But not sure if you have Auto Transfer Switch Or Not!
Are you sure your switches are on by the door for power to the coach and the Inverter. Somebody a lot smarter than I will have you an answer shortly. Was it working before this happened? How long ago?
Good Luck
Dennis King is offline   Reply With Quote
generator, power
