Old 10-10-2018, 07:48 PM   #1
Walter Pigeon's Avatar
Georgetown Doghouse?
How do I remove the doghouse and or the radio/control bezel ?? I get the carpeted cover unlatched (2 latches) but it doesn't want to come out from under the center bezel... 2011 337DS
Thanks !!Click image for larger version
Walt, Lanie and our fur baby "Foxie" loving life in the RV
2011 GEORGETOWN 337DS
Walter Pigeon is offline   Reply With Quote
Old 10-10-2018, 08:58 PM   #2
Kanadian Kamper
kenandterry's Avatar
Your set up is exactly the same as mine.
Letís assume you know how to remove the separate unit with the cup holders....you remove the screws at the bottom center of each cup. This gives you just a little more space between the center console and the doghouse.
You unlatch the 2 latches and.......if youíve never removed the doghouse ever, itís going to be a fight as the dirt, heat, and time have almost ďgluedĒ the rubber gasket of the doghouse to the trim piece on the floor. Stick with it......it should come apart.....but itíll be a bit of a fight.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 10-10-2018, 09:37 PM   #3
Thanks !!Attachment 188849
Undue the latches, slightly pickup the rear of the dog house and slide away from the console. Like kenandterry said, the gaskets may have stuck on the dog house frame.
The cup holders are attached to the dog house cover.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 10-10-2018, 11:23 PM   #4
Thanks gents... I will give it another shot !!
georgetown
