Originally Posted by RudysWorld
Double check tire inflation, dealer had mine at +100, Forrest River recommends 90 psi and Michelin recommends less based on weight. When I got tires to 90 psi handling was much better.
Rudy is right!!
Not only does the correct tire pressure matter, (A LOT), in handling and driveability).
But it matters to have the correct pressure regardless of where you drive. (Local temperature is a BIG factor)!!
We recently traveled to Washington from SoCal. As the temp dropped when we travelled north, so did the tire pressure.
My gas mileage decreased, and I noticed more of a "softness" in handling/ cornering.
I spoke to a tire manufacturer and asked them at what temp should I be measuring the 90lbs pressure, (before driving each day).
OR, should I be making "adjustments" to the 90 lbs. pressure depending on local temp.
They said ....... "90 lbs is 90 lbs."
if the temp in SoCal is 70 degrees, make sure your tires start out at 90 lbs before you drive.
If you're in Seattle and the temp is 40 degrees, make sure your tire pressure is 90 lbs before you start driving.
Makes sense!
I've invested in an RV air pump to insure I can have the correct tire pressure regardless of where I travel and the local weather!
