Originally Posted by greydragonhd
I have a class A Georgetown. The passenger seat is the same as the driver's seat except it is up against the wall, under the window. Can it be moved away from the wall safely?
Does your factory provided passenger seat have folding armrests on both sides?
If yes, it’s positioned appropriately.
Is your concern that your passenger cannot swivel the seat?
Have you tried both seats?
On my past 2010 Georgetown 330TS, the driver seat was virtually impossible to swivel 180 degrees completely around because of the steering wheel. It was an incredible fight to do it, but the back of the seat was so upright, I didn’t bother. I’d just turn it 90 degrees and live with it when/if necessary.
The passenger seat was able to swivel 180 degrees, but you needed to put the back up straight, and at the same time, slide the seat on its track to make it actually work.
