Now, this is simplistic, but pretty much what you need to do.
First off, you don't use the GVW you use the curb weight of the Jeep, which is 3,970 to 4,439 lbs. There is a sticker in your coach that lists the GVW and the GCVW. Subtract the two and see if you have enough left for the Jeep. The towbar will weigh around 50 lbs. GVW is 20,500 and GCVW is 26,000. Looks like you can handle about 5500 pounds, but I bet the hitch tops our at 5,000. Looks like you can do it.
2015 335DS
