12-15-2017, 02:33 PM
Georgetown windshield wipers
We have a 2016 Georgetown 335DS. Need to replace the windshield wipers. I believe they are 28" but cannot identify which brand or type was installed. Have looked at several brands but not sure which are best. Would appreciate recommendations for brand and size
12-15-2017, 06:52 PM
Brand is up to you.
Just get the blades that say they work with J hook or has the adapter to hook to a J hook arm.
I would look at a truck stop and wee what they have.
The important part other than the J hook is the thickness and size of the rubber. Take a look at a few and youwill see the cheaper ones are thinner.
That is the best advise I can suggest other than take on blade off and take it with you.
Good luck and Merry Christmas and Happy Hanukah.
Iggy
12-15-2017, 11:14 PM
I believe the J hook is 9mmx4mm. I bought 28" Bosch from Autozone and the adaptor was in the package. Mine were 32" as fitted but those blades were 40.00 each so I reduced to 28'' and they work OK (don't need to see passing aircraft!!)
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
12-16-2017, 07:21 AM
I got my GT wipers at Wally World for $8 each and they came with adapter for the wide or narrow "J" hook.
12-17-2017, 03:45 PM
Now if there was a way to keep them pressed tight against he glass.
Daryl
2014 Georgetown 351ds
12-17-2017, 04:23 PM
I just replaced mine with RainX blades. Ordered online for $15
12-30-2017, 12:10 PM
Yes,there is a j type spring that attaches to your wipers. You can get that at places that sell or repairs big rigs
12-30-2017, 04:02 PM
There is a way. The spring needs to be tighten. I adjusted mine a little too much though and will loosen then up when the weather gets warmer. Not easy to do though. When I get a chance I will take a picture of what to do.
2013 Georgetown XL 378
2008 Honda CR-V
12-30-2017, 07:13 PM
Yes, not easy but I did mine and if I can do it anyone can. Wrapperman said he would show what needs to be done. It just takes a little more tension on the spring. I did mine by moving the wedged in place piece of metal that the spring is attached to on one end. Maybe wrapperman has a different approach.
12-30-2017, 07:37 PM
My 2016 335DS has 28 inch blades which I replaced with Bosch Blades
12-30-2017, 10:18 PM
Bubbles I think you and I did the same thing to tighten them. Easy to remove the spring but hard to put the spring back on.
Hopefully the weather permits me to remove the wiper blade and take pictures. The forecast is for 17 in the morning for the next 3 days. Pretty cold for us East Texans.
2008 Honda CR-V
01-05-2018, 04:55 PM
New:
AGREED!
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
01-05-2018, 06:45 PM
After I tighten my wipers they now press too hard against the windshield. This weekend I am going to loosen them a little.
2008 Honda CR-V
