Old 08-08-2020, 11:27 AM   #1
NXR
NXR's Avatar
Got the factory-installed sliding tray in the rear compartment? Check your bolts.
I have the sliding tray and love it. I was showing it to a friend and he asked how it's secured to the pass-through. So we looked and it uses four carriage bolts. Three of the bolts are not in the square hole. <sigh>
Ray
Name:	Tray Bolts.PNG
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 08-08-2020, 12:01 PM   #2
Dodge Guy's Avatar
Excellent work Forest River. Real good attention to detail....not to mention the great quality control!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 08-08-2020, 12:24 PM   #3
When you can't fit a square peg into a square hole....you have a problem.
TheWolfPaq82 is offline   Reply With Quote
Old 08-08-2020, 02:22 PM   #4
NXR
NXR's Avatar
Technically, I now have the problem but yeah, that is a great way of putting it.
Ray
Old 08-08-2020, 03:04 PM   #5
NXR
NXR's Avatar
Fortunately, the underside looks better although I have not yet corrected the problem. The carriage bolt goes through a square piece of frame.
This is on the driver side looking straight up and would be the rear attach bolt on that side. That's probably why it's rated for 500 pounds, equally dispersed, and feels rock-solid.
Ray
Old 08-09-2020, 10:58 AM   #6
Btm
Bolts
Thanks for the pics.
I have just learned a new way for bolts to work.
If it don't fit, force it. Hammer down first, then tighten until it almost breaks.
Glad you found the bolts. If one broke, your things could have been dumped or your tray distorted.
Btm
Ben Moore
Temple,TX
2019 GT5 31L5F, 2014 Wrangler Unlimited
CHF rear, CHF front, Sumo springs front
Btm is offline   Reply With Quote
Old 08-10-2020, 10:17 AM   #7
Salesman Quote
Ray
"That's the way they make them now. See the plastic wire stripping and saw dust? We saw that during our PDI and left it so you would have something to do with your time."
campers302 is offline   Reply With Quote
Old 08-10-2020, 04:49 PM   #8
NXR
NXR's Avatar
Had you left the word "now" out of your first sentence, it would make ore sense.
Ray
Old 08-11-2020, 09:36 AM   #9
You are correct
Ray
It ore would have.
Be safe &
Old 08-11-2020, 10:34 AM   #10
NXR
NXR's Avatar
It ore would have.
Ha ha, nice. Maybe I was referencing some iron-headed people. Or not...
Ray
factory, led, bolts, check
