08-23-2017, 05:35 PM
Hard Wire vs Pedestal Surge
For me the original thought/decision was to install a hard wired surge protector for many reasons, but an item I had never considered is that if the circuit board in the surge protector goes out, no 120vac power is available from any source (generator, shore power, or inverter!). The bypass function does not work/function in this situation. I am making jumping cables (using "alligator" clips on 6 or probably 10 awg wire) to manually bypass the relay temporarily until I receive the replacement parts.
So add this factor to your purchase decision!
08-23-2017, 06:20 PM
Always Learning
Some people install them with twist lock connectors on either end and carry a jumper cable in the case that the surge protector dies. Let's them bypass it in the cabinet.
I figure I'll just uninstall it or boondock for a couple of days until replacements arrive.
08-24-2017, 03:20 PM
I guess the real question is why did you install the surge protector to filter both shore and generator I did shore only to prevent such problems as you have. The generator has built in urge protection .now that your surge protector has died just remove it and use splicers to put the cable back togeather available at any hardware store. Should take about 20 to 30 minutes.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
I initially purchased a pedestal Surge protector. When I am concerned about the surge protector, I plug it in in the power bay and use my 50Amp extension cord to connect to the pedestal, leaving the surge protector safely in the bay.
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
08-25-2017, 01:27 PM
Buy a pedestal mount. I installed a 50 amp surge protector in our first motorhome, but then, had to buy another one when we traded the motorhome in on a 40' fifth wheel.
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
08-25-2017, 01:40 PM
Good idea! I always worry about someone taking my surge protector. In some cases, I can lock the pedestal cover with a padlock but in others, I can't.
And then there was the campground where the receptacle was installed upside down and there wasn't enough space to plug in the surge protector
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
08-25-2017, 04:38 PM
7 Year Class A RV'er
Two things for you that should ease your mind. First, should the circuit board fail, there is a device inside the unit that allows you to bypass the controller and get power. Secondly, since I had the same concern, I installed mine so it could be removed from the power feed at any time. To do this, I went on Amazon and bought two 50A range cords and two 50A receptacles. You want to be sure you don't wind up with a hot male plug that could shock you, so you want to put a receptacle on the coach end of your shore power cable. Then put a range cord on the incoming power side of the EMS and a receptacle on the coach side of the EMS. Then put the second range cord on the incoming power side of the coach's transfer switch. Plug all these together and you have power. If you want the EMS removed, just plug the male end from the transfer switch into the receptacle on the coach end of the shore cable.
2015 Legacy SR340 360RB
08-25-2017, 06:59 PM
Phat Phrog Stunt Crew
You can buy a pedestal unit and two plug ends to match each end of the surge protector. Go to where you would install it behind the fuse box, cut the power cable and install the cord ends. You can then install the pedestal unit like a hard wired one. If you have troubles, all you need to do is unplug the unit and plug the line together without it.
2014 Wildcat 327ck
08-25-2017, 07:38 PM
I installed the hard wired 30amp with the readout near the thermostat. I like the option of being able to disable the unit from the switch on the readout.
08-26-2017, 12:44 PM
Solved
The problem with the HW50C was in the control board (CB). Specifically I located a burn spot on the backside of the cb and when I turned it over it was visible on one of the leads to a larger resistor. The surface of the ceramic resistor did not appear to be normal. It was faded/corroded/cracking - a manufacturing defect? or the result of the failure. With the replacement cb installed, everything is functioning properly.
