Originally Posted by CA Fisherman
Did you change the electric propane valve or just the detector panel?
Just changed the detector
I must say the new valve looks a lot stronger than my original one installed in 2012.
The actual coil is much larger in size and that relates to more coils which related to be a strong hold open so the gas can flow.
I and many have mentioned how hot the OEM gets which has been normal for my 10 year ownership.
The new one says that it may get hot which is normal.
Here is the comparison
Original OEM Valve 2012
12VDC
9.5 watts
1.26 amps
65 psi max
New Valve 2020
12VDC
12 watts
1 amp
312 psi Max
The new valve looks like it is much better in many ways
Less amps and higher Max PSI.
I'm sure the drop out/off coil is stronger seeing the actual size of the coil and center shaft.
If the fittings size are the same I may change it out when I get home because it needs threat sealing paste.
