07-28-2021, 01:54 PM
Heeeeelllllpppp!!!!! with Georgetown engine fail to run
Hey all I have a renter currently in Missoula Montana. I have a 2011 Georgetown 350. Yesterday they stopped to fill up drove around the parking lot and the unit died after sputtering. They’re able to get it started but when putting it in gear and giving it gas it sputters and dies. From the research I’ve done on the forums it sounds like a fuel delivery issue. I Cannot find a mechanic or resource to help them out. I feel terrible. Good Sam hasn’t been able to assist outside of towing them to a campground last night. Does anyone have resources out there that can help? Please PM me here if you can assist. I’d greatly appreciate it. Robert
07-28-2021, 02:00 PM
Might be a dumb question, but did they put the right fuel in it?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-28-2021, 02:10 PM
Yes, it’s their third fill of the trip
07-28-2021, 02:47 PM
If you can’t find a mobile mechanic, call some shops and see if they can fix it quick, have it towed and pay for a hotel plus Uber ride. Maybe just a fuel filter on the frame rail and not in the tank. Is there a check engine light?
07-28-2021, 06:01 PM
Sounds like the fuel pump is gone.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
07-28-2021, 06:29 PM
They’ve found a shop across the steeet from the park they’re in now. He’s looking at it tomorrow. There is no check engine light on. Does anyone have a part number for this? I’d like to get ahead of the curve and get it ordered if we can.
07-28-2021, 07:48 PM
2020 Georgetown GT5 34H5
07-28-2021, 11:05 PM
May look at the fuel pressure regulator as well....
2014 Georgetown 378 XL
2022 Aprilia Tuareg
2005 Jeep Wrangler "Toad"
07-29-2021, 09:44 AM
OP, any news yet?
07-29-2021, 12:41 PM
Director, FROG
Third fill-up, but likely not at the same station. Might they have gotten bad gas, or could the fuel filter be clogged?
07-29-2021, 03:50 PM
Or filled up with E85 to save a few cents per gallon.
Ray
07-29-2021, 06:13 PM
You had this same problem when you were using it about a year ago. You never did come back to tell everybody who helped what the resolution was then.
Maybe it’s the same thing.
https://www.forestriverforums.com/fo...ml#post2383931
Bruce
07-29-2021, 06:27 PM
I guess we will never know what the problem was!
07-29-2021, 08:47 PM
He just worked on the wiper motor. He probably has major issues with wiring.
07-30-2021, 04:36 AM
No.
This is the beginning of his original post in that thread:
“2011 FR Georgetown 350 bunk house. Ford v10 engine. This weekend we had trouble getting the coach to start after fueling up. Turned key and nothing at all..
Bruce
07-31-2021, 11:34 PM
Is there a fuel pump cutoff kill switch somewhere that got tripped? Or a Positive Air Shutoff flapper coming off from the air intake that got tripped? Quick easy things to look at before delving into more invasive and expensive “fixes” first.
