Our front unit (15K Dometic heat pump) has gone out on us during our current trip, too. Blows, but no heat or cool. When I got to checking, I found the "hidden" paperwork the dealer stuck in a folder that shows Dometic warrants the units for TWO years from date of delivery of your coach, not the standard one year. I spoke with Dometic customer service and they verified it will be covered, including labor to diagnose, remove the current unit and install the new one. They even said if you want to upgrade your unit, you can work with the dealer repairing it to do that. It has to get diagnosed and repaired by an authorized Dometic rep. I'm hitting up CW as soon as we get home in a couple of weeks. You should be under that same warranty. I think I've lost my refrigerant charge, but that means they have to replace the unit (can't be recharged). If you had ice, that would be an indicator of low refrigerant levels, too. Good luck.
2015 Legacy SR340 360RB
