Old 11-04-2017, 12:57 PM   #1
Dennis King's Avatar
HELP Please? Embarrassing Moment! Georgetown 364TS
Stuck in the grass at my house next to driveway.
Heavy duty tow truck coning to wench me out!
Anything to watch for? He will hook up to the rear probably trailer hit h bracket No hitch yet!
They said he would wench it out!
Anything to watch for??
Not sure how much experience these guys have!
Vehicle is 23000 pounds
Don’t want to bend frame or put tork on slides etc!! Thought I would ask since they will be a couple hours ! Thanks Dennis
Dennis King is offline   Reply With Quote
Old 11-04-2017, 03:36 PM   #2
Do not let them hook up to hitch. The need to go around the axel.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 11-05-2017, 01:36 PM   #3
Old 11-05-2017, 01:45 PM   #4
Scoundrel
HangDiver's Avatar
Take photos.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 11-05-2017, 01:48 PM   #5
Flybob's Avatar
Update?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-05-2017, 02:11 PM   #6
I tried pulling with Navigator on a tow rope for pulling out cars from the snow but it pulled one hook end off one end of rope. Small Tow truck came with a chain and said he would easily get it out with no problem. I said you are going to need a bigger truck[emoji1] I was only 3 inches deep and the warranty for 1 year covered 2 hours with one truck or 1 hour if they needed two trucks. Pulled right out no problem with slightest pull ever I think. I don’t think he pulled hard enough to hurt anything! He hooked to hitch . It was a small chain I thought sure it would break
Old 11-05-2017, 02:25 PM   #7
Thanks Hopefully I never need another pull!
Old 11-12-2017, 04:13 PM   #8
I watched as a front end loader towed a high end coach after being stuck in sand as i was he bent the stainless steel skirt very bad I was asked if i wanted to be towed, I declined. I went to Home Depot bought a 4 X 8 sheet of plastering lathe had then cut it in half,
put jacks down did a little digging under tires put one under each of the the duals and brought the jacks up just barely touched the gas and walked it out no problem
aw12691 is offline   Reply With Quote
Old 11-12-2017, 04:45 PM   #9
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
With hydraulic leveling jacks this may very well be the safest way, not necessarily the quickest, to get unstuck.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
georgetown
