Old 05-06-2021, 12:07 PM   #1
Help with Lights out 2014 Georgetown 351ds
A few weeks ago the kids nightlight bulb burnt out so I went to remove all but one of the bulbs above bathroom sink - i broke a bulb and I guess created a short.
The light over the bath sink no longer comes on and at the same time the led ceiling light in the master went out.
That said - everything else works, the ceiling like in the bath works, the sconce lights in the master works and all the other lights work.
It is just the light over the sink and master ceiling.
I have checked
- the breakers under the bed
- the fuses under the dash to the left of the pedals that are so easy to reach
- the fuses attached to the house batteries
- the fuses in the closed panel above the house batteries
- the breakers by the batteries
I am stumped, any ideas where to go next? Note I have not replaced the broken bulb yet - it seems crazy they be wired in series in that if one is out they all go out...
Appreciate any ideas.
While i am here, my retractable awning looks like it has a half inch rip on the very edge - should i stitch it or maybe wrap a couple inches of 4 inch flex seal tape/ other to slow the tear?
Leslie2014351DS is offline   Reply With Quote
Old 05-06-2021, 11:01 PM   #2
Did you check the 12 volt DC panel in the bedroom nect to the 120 volt circuit breaker panel?
Looks like this one.
You get the idea where it is next to the 120 volt panel
Name:	Screenshot 2021-03-15 181201.jpg
Old 05-07-2021, 07:07 AM   #3
Your awesome
I can't believe I did not see that, by far the easiest to access.
I should have just asked first, we spent 2 weeks in the dark and so much time pulling the wrong fuses and searching the web.
It was the third one down, thanks so much.
Have a great weekend!
Old 05-07-2021, 07:53 AM   #4
Glad to help and don't forget to check the Private Message I sent you here.
See you on FB.
2014, fuse, georgetown, light
