09-14-2021, 12:59 PM
#21
Originally Posted by IDguy
Note the fragments aren’t sharp: tempered glass. Stresses can build up from temperature changes. Had it been used with very hot water?
They are sharp but break up in pieces that are too small to form daggers.
I have 5 vessel type in my house with no problems but they are only 3 years old and 17mm thick.
09-14-2021, 01:02 PM
#22
They make new ones that are stamped steel. May be the way to go so you can get rid of the other ticking bomb!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
09-14-2021, 04:23 PM
#23
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
09-14-2021, 06:36 PM
#24
Originally Posted by Frank DeFeo
Have a 2016 369xl. Last night while we were sleeping there sounded like we had an explosion with glass flying everywhere. We have a rear full bath with double vanity and 2 glass sink bowls. One of them literally blew into hundreds of pieces sending glass everywhere. All over the bath with glass shards flying onto the bed and as far as into the living room and onto the sofa. At first I thought that one of the wall mount lighting fixtures fell off the wall and shattered it, but nope, not the case. Nothing fell on it, nothing hit it, for simpler terms it just exploded as I said into hundreds of pieces. Thank god none of us were near it. Attachment 262752Attachment 262753
Good that it was made of safety glass. Looks like when a car rear windshield breaks
09-14-2021, 08:39 PM
#25
Just a guess but if the drain fitting was just a bit too tight and it got a bit cold under the sink (here comes the physics) the disparity in coefficients of expansion and contraction could account for additional pressure being put on the glass as the drain fitting contracted. Just a guess.
2021 Rockwood Mini Lite 2205S
2011 Ford F-250 Super Duty 6.7L Diesel
09-14-2021, 09:11 PM
#26
Tempered glass is always under stress. Nothing to do with pyrex type glass. It isn’t safety glass either. Windshields are made of safety glass which is laminated with a plastic core. That is what keeps it from shattering into little pieces which would be disastrous if hit by a road hazard like a pebble. Safety/laminated glass can be cut and tempered glass will shatter if one attempts to cut it, since the outer tempered layer is under tension.
Not sure about the drain tension idea since they have rubber on the drain fittings. That is at least the household varieties. I have installed several and never heard about any breaking. Like anything if you get enough out there the odds increase. Especially with inferior quality products.
09-14-2021, 09:27 PM
#27
Any item made of tempered glass can explode under the right circumstances. Here is a good video explaining why and how:
09-14-2021, 09:48 PM
#28
Sounds like what I just said. I guess a video makes it better.
09-15-2021, 09:49 AM
#29
Originally Posted by dmctlc
So I never heard of this before and luckily we've never owned one with this sink type. My DW doesn't care much for the style, I guess I'm glad she doesn't now. This type is out in many MHs I've seen at shows, folks we know that owned ones with them, etc.. of course now that I've read up on this its also has happened in homes as well and causes range from manufacturing process, improper installation, temperature change and misuse. Wow I learned something today. I'm sure its a small percentage that this happens to but that happening late night could give someone a darn heartattack, of course thats JMO. Now is it just a FR issue or others, just curious. Glad FR is replacing them Free of charge but whose doing the installation and, as mentioned are they giving them matching sinks?
From what I have read and researched this is not limited to FR only, has also happened in residential use as well. Yes matching sinks, I will do the install.
09-15-2021, 10:02 AM
#30
This just happened to us. We were not in the RV. Came in to clean the RV before a trip and there was glass everywhere. Nothing hit it?
The good news e-trailer sells them for $55 a piece I purchased two becasue I was afraid they would not match. The replacement is so close that if you didn't know one had broken, they look the same.
2014 Georgetown 360 DS Front & Rear RoadMaster Sway Bars Sumo Springs & Safe-t-Plus Stabilizer
Koni Shocks Blu-Ox Rear Trac Bar
2020 Chevy Equinox Silver sled
09-15-2021, 10:07 AM
#31
If it is like other RV items they always seem to choose the cheapest. They are a very old if not the first style of indoor sink. Everything from petrified rock to wood has been used.
I wonder if there is chart somewhere that shows failures based on brands.
I prefer Kraus when I build, but I never did track houses.
09-15-2021, 10:32 AM
#32
Yes exactly what he said.
DISPARITY IN THE COEFFICIENTS OF EXPANSION AND CONTRACTION OF THE WHOOSY WHATS AND THEM THAR WHICHAMAJIGGS.
Perfect explanation. Thanks
09-15-2021, 11:10 AM
#33
This is just a tempered glass phenomenon. Any defect in the glass is an incident waiting to happen. It happens on glass doors to ovens. And it has been a huge problem for the last decade on sunroofs in vehicles. We had our sunroof explode (as opposed to implode, it stayed together) while driving down the highway. Sounded like a shotgun went off next to my head.
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
09-15-2021, 05:43 PM
#34
Rolling on & on & on
Happened to us with a glass computer desk
We had the same kind of spontaneous explosion happen in the middle of the night to our glass computer desk. It had glass shelves down one side and the bottom one exploded. It was really freaky. Shards of glass were everywhere.
Keith & Kathryn C. (KC2go)
2021 Georgetown GT7 36K7 "Kacey"
Palomino Puma 30' TT
Jayco C-class
Coleman P/U
