If you have a Suburban - Atwood water heaters should be similar, hook up your water hose as normal, open the pressure relief valve while filling the water heater, close it once it starts spitting. If you don't have a hose connected to the rv turn on the water pump, with water in the freshwater tank obviously, as when you're dry camping and open the pressure relief.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
