Originally Posted by grumpyer
So if I'm plugged into shore power, wh is empty, switch outside is on but not inside I should be ok?
Anyone?
Yes. But only IF the inside switch actually controls the heater. In the OPS case, it didn't.
But the OPS control was one of those new-fangled computer-type control centers. If yours has actual switches, you should be OK.
Only way to know is leave the outside switch on, turn both inside switches OFF, and wait to see if the WH cools down (or never heats up).
2011 Traverse LT, 3.6L, FWD
