Old 10-14-2019, 09:38 PM   #1
Gordalder's Avatar
Hot water tank always on
I have a 31L5 and I think the hot water tank is always on electric. I brought the coach home to winterize it. I plugged it in to charge the house batteries, and I fired up the android control panel where the heat is normally controlled from. The gas, and electric hot water were both turned off. Later when I was the emptying the hot water tank the water that came out was hot, not cold. The switch on the hot water heater was ON, but the soft controls were set to OFF.
Anyone else notice that the hot water tank is always on?
Any ideas as to why my hot water heater might always be on?
2018 Forest River Georgetown model 31L5
Flat towing a 2019 Chevy Spark
Gordalder is offline   Reply With Quote
Old 10-14-2019, 09:53 PM   #2
wmtire's Avatar
If you have a suburban tank type heater, you have a switch on the face of the water heater on the bottom left hand corner, that must be turned off.
A lot of the precision Plex type control panels, even though they have a place for the electric heating element, it's only controlled actually from that switch on the face of the water heater. That may be why the electric heating element is always on for you as the panel control is not doing anything.
Also the water could still be hot from previous heating as we have no time frame of when you turned it all off, vs draining the tank.
If the electric element is still on, and you drained the tank, you have probably ruined the electric heating element by now, unless you were disconnected from any form of shore power.
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 10-14-2019, 10:20 PM   #3
Gordalder's Avatar
The coach was in storage so the the water heater was never on. As soon as I felt the hot water I turned off the switch on that is on the heater.
Maybe I am confused about the operation, but I assumed that the switch on the water heater would be turned on once a season, and then I would control turning on and off of the heater from inside the coach. Didn’t make sense to me that every time I wanted hot water I would need to remove a panel to turn it on. That was the what the switch in the coach was for. Am I wrong?
Old 10-14-2019, 10:23 PM   #4
wmtire's Avatar
Is your switches to the water heater inside the RV, in a digital control panel or are they physical manual type rocker switches
Geaux Tigers!!!!
Old 10-14-2019, 11:07 PM   #5
Gordalder's Avatar
Digital panel inside Coach.
Old 10-15-2019, 02:20 AM   #6
wmtire's Avatar
We have threads where even though your digital panel has the electric heating element option in the panel itself, it does not actually control the electric heating element. In these instances, the actual rocker switch on the face of the water heater is the only way to turn the element on/off.
I have a feeling this may be the way yours is too. Others with the same digital panel may chime in to confirm or deny this.
If yours is this way, then with the rocker switch ON, anytime your connected to 120 volt AC power, the electric heating element will be ON, no matter what the digital panel switch is.
Here is a recent thread on this matter at least where Cedar Creeks are concerned and their digital control panel not being able to control the electric heating element side:
http://www.forestriverforums.com/for...ml#post2162658
and another using the in-command system, where the electric heating element option is not controlled by the digital panel:
http://www.forestriverforums.com/for...ml#post2061638
http://www.forestriverforums.com/for...ml#post2120600
Geaux Tigers!!!!
Old 10-15-2019, 06:58 AM   #7
wmtire's Avatar
Suburban makes several different models of their tank type water heaters (and Forest River uses them), which are mainly the SWDE and SWDEL models. The difference between the two is that the SWDEL model has a 12 volt DC/120 volt AC relay incorporated into it that allows for the addition of an inside switch/control to turn OFF/ON the electric heating element.
Both the SWDE and SWDEL models have that same rocker switch on the face of the water heater for the electric element too.
You may can go outside and open up the cover to your water heater. There will be a tag there that tells what model water heater you have. If it is the SWDE model, then most likely your digital control panel, even though it shows an electric heating element option...will NOT actually function.
From Suburbans website: "The model and serial number information can be located by opening the water heater access door on the outside of your RV. The silver colored data plate with black printing is located on the right side of the metal control housing as you face it from the outside. The model number will be located on the top line of the data plate and will begin with "SW", "SAW" or "V". The nine digit serial number will be on the bottom line."
This thread explains the differences between the SWDE and SWDEL models, with the wiring schematics.
http://www.forestriverforums.com/for...ore-36197.html
Geaux Tigers!!!!
Old 10-15-2019, 08:26 AM   #8
BirdeeGirl's Avatar
I also have a 31L5. I think the icon on the control is for tank heater not water heater. Only gas can be controlled from the pad. That’s only an assumption though as I didn’t get any manuals whatsoever with my RV.I was told by the dealer that they weren’t provided anymore and had to be downloaded.
BirdeeGirl is offline   Reply With Quote
Old 10-15-2019, 12:20 PM   #9
Tom48's Avatar
Ours is a Sandstorm, toy hauler and while I have some complaints about that factory, I am greatful to have a hardwired switch, right next to the gas waterheater switch that gives me positive on off control inside, after I switch the electric on at the suburban heater outside.
That extra ten bucks worth of hardware is a great investment.
Tom48
In Sunny So Cal /w
2004 SD F250 now BULLET PROOFED
2017 Sandstorm 250 TH, with
8 wheel TST TPMS and
The Hot Air Balloon RESTLESS
Tom48 is offline   Reply With Quote
Old 10-16-2019, 08:57 AM   #10
Gordalder's Avatar
Looks like I have SWDE model, so the software switch is just for show. One funny thing I “think” my hot water electrical power source might be from inverted power. Is this normal?
Old 10-16-2019, 09:04 AM   #11
The switch just turns on/off the gas. If the inverter is wired directly into the main bus (powers everything 120 volts) then yes it is inverter powered and you certainly don't want that element on when you're on battery/inverter.
We do a lot of boondocking and rarely use the electric element but it is nice to have when we are hooked up.
nayther is offline   Reply With Quote
Old 10-16-2019, 09:35 AM   #12
R/Vs with inverters are wired differently between models.
I see you don't have a signature line telling us what R/V you own nor did I see that information in your profile so when you ask the question... "Is that normal?"... we have no way of knowing what is normal for your unit and are only guessing.
Many inverters are wired to only power up an outlet for a residential refrigerator.
Some are wired up to include another couple outlets, like for the tv.
A few are wired to power the entire rig.
If you are not familiar with how to use a multimeter... with the shore power off and the inverter on... plug a light into the outlet where the water heater is plugged in and then turn off the inverter. If the light goes out, the water heater element would be powered by the inverter. Not a good thing!
Days Camped: '17=30 '18=51 '19=58 '20=55
Old 10-16-2019, 11:05 AM   #13
NXR
NXR's Avatar
No, it's not normal for the Georgetown GT5 series.
If you have an inverter control panel that shows how many battery amps the inverter is using, watch that number while flipping that rocker switch inside the water heater on and off with shore power disconnected. If the inverter is powering the water heater that number will go way high.
If you have a Xantrex inverter, the inverter is bypassed when shore power is in use. At least it is on our 2,000 watt inverter.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 10-17-2019, 07:49 AM   #14
Only Electric Switch on Heater
I made the same mistake on my 2018 31L5. The "switch" on the One Touch is for your tank heaters.....not water heater. The only switch on this rig is on the water heater itself for electric. Look close at your One Touch....it says TANK HEATER, not water heater. Save yourself some time....took mine to dealer for this problem only to be laughed at.
Bob
bobotty is offline   Reply With Quote
Old 10-17-2019, 08:02 AM   #15
wmtire's Avatar
Bob
Surely they didn't laugh at you, but with you.
Geaux Tigers!!!!
Old 10-17-2019, 08:14 AM   #16
NXR
NXR's Avatar
With my GT5,the switch on the app (and on the panel inside marked "Water Heater") turns on the propane water heater. The electric water heater is on all the time unless I trip the breaker or open the water heater outside panel and turn the rocker switch in the lower left corner to "Off".
Open the panel for the water heater and find the model. SW6DE, the one I have, does not have a remote switch for the electric heater. SW6DEL does.
Yes, a good way to burn out that electric heater is to think the heater is off, drain it and the electric heater is actually on. That may have happened to you if you also have the "DE" version.
Running both is supposed to give you faster recovery when using hot water.
Ray
Old 10-17-2019, 09:10 AM   #17
Gordalder's Avatar
Bob
Very interesting, now I can’t wait to get the coach out of storage next week to check the label on my One Touch app. Do you know which “Tank” get heated. I looked at the User Manual (unless) and found no information on the One Touch app for my rig.
Old 10-17-2019, 09:11 AM   #18
Gordalder: If you're comfortable with rewiring your WH's outlet, you can easily add a standard house switch inside the coach to turn the electric on/off. Some pics of mine, with a wiring diagram is attached.
If you have a "speed outlet" like this one,
Name:	Speed box outlet.jpg
replace it with a standard duplex outlet and electrical box
Cut a hole where you want the switch and install an electrical box
Use a standard house light switch with a pilot light (so you know when it's on/off), and wire it to the outlet with 12-3 romex.
2011 Traverse LT, 3.6L, FWD
Old 10-17-2019, 09:21 AM   #19
Gordalder's Avatar
Attachment 217464
Attachment 217465
Attachment 217466
Attachment 217467
That looks excellent. Another project for me to complete this winter in Florida. It just annoys me that I have so many RV projects on a unit that I purchased new, that should be standard equipment.
Old 10-17-2019, 09:32 AM   #20
There's another option, too. You can wire a 12VDC switch similar to how Suburban does it, but you'd need to wire a 12VDC relay into the 110VAC line. Here are the Suburban wiring diagrams.
Name:	L Model 12VDC and 110VAC wiring together.jpg
hot water, tank, water, water tank
