12-20-2020, 07:58 PM
House batteries.
07 Georgetown,powered by ford v-10, going down the highway my alternator should be charging my house batteries?
12-21-2020, 07:22 AM
Charging
My 2019 charges while traveling. I don't know if your 07 does.
I would check battery voltage before traveling and then again after some miles. If you were low to start you should have some increase.
Btm
Ben Moore
Temple,TX
2019 GT5 31L5F, 2014 Wrangler Unlimited
CHF rear, CHF front, Sumo springs front
12-24-2020, 06:15 PM
Yes it does, or at least it should be.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
01-01-2021, 11:43 AM
my 2006 34.4 doesn't and never has went it was in shop years ago I asked Tec so NO. He told me there is a option for X amount or money. I said no forget it I just keep my battery tender on when at home and never had a problem.
01-15-2021, 12:00 AM
Steve from Maine
DC to DC charger
I use a RedArc DC to DC charger. It will get the most out of your alternator to properly charge your batteries. Mine is good for acid batteries or lithium which I have. They come in different amp models such as 25 or 40 etc. Since I have a lot of solar I only have the 25 amp one so as not to overwork the alternator. My battery monitor always shows it pushing at least 25 amps while the engine is running(+ solar). It is a smart charger and will also accept solar also.
i like the Redarc over some other brands as it is small, waterproof and will take extreme heat.
Retired UPS Driver
2015 Georgetown 270s
640W solar, 60a Renogy MPPT, 510ah Li
10CU.F GE dc only fridge
2019 Jeep Wrangler Unlimited
2008 Yamaha WR250R
01-15-2021, 12:05 AM
Steve from Maine
Check voltage
Check the battery voltage when not running and then when running and there should be a noticeable difference.
Retired UPS Driver
2008 Yamaha WR250R
01-15-2021, 09:29 AM
Yes thy should be charging. Been that way for a long time. If they are not check for blown fuse or popped breaker.
01-15-2021, 04:25 PM
2013 GEORGETOWN 351 DS
I have owned many MH all of our units have always charged the house batteries when the engine was running.
I would bet your is designed to work the same way but something was missed during the build or something was installed wrong.
GRV
We love to Roam
2013 Georgetown 351 DSF
 2017 Honda Civic
01-24-2021, 08:45 PM
Add two more 6 V batteries so now I have a total of 4 6v batteries.
Next thing I need to figure out how many solar panels I need and what size inverter to keep batteries charged .
01-24-2021, 11:17 PM
Converter(not inverter) should be ideally 25% of your total battery bank capacity. 4 6v batteries connected in series/parallel for 12volts will have around 450 amp hours total so converter could be as large as 112 amps.
That said your existing converter could be a 55-60 amp converter and going larger could overload the wiring, both the 120 volt feed and DC output wire to the batteries.
If you change converter plan on doing some wire and breaker upgrades.
The OE converter should work fine especially if you add solar.
There the only limits are space for panels and money.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
01-26-2021, 12:37 AM
Yes
01-26-2021, 04:23 AM
Yes it should. With the engine off and no shore power, does you starting boost switch work (at least make a clunking noise) On most rigs a bad isolation relay makes the alternator stop charging the house (and other things) not work.
2015 335DS
