If it's like our 2020 dinette, you don't need to. They do lift straight up on ours, though. There's an angle bracket screwed to the wood "wall" back and a hole drilled in the wood of the cushioned seat back. The bracket on the "wall" slips in the hole. Hokey but it works.
To turn it into a bed on ours, remove both bench seat cushions. Under the table at the end closest to you is a lever that gets turned to the other side to unlock the table. Then the table gets pushed down. Install the bench seat cushions. Then take the third cushion and wedge it between the other two. You'll swear that third cushion is too wide but it's not. Just work your hand along each of the edges to push them down and then it stays in place.
Unless, of course, you do not have the third cushion. Then you have a different problem...
Ray
2020 Georgetown GT5 34H5
