Originally Posted by David658
It’s the valve inside the pump that’s bad. The fresh water tank fills when hooked to city water. According to FR that’s a common problem.
OK I used to have this happen on my Georgetown 378TS and I decided enough of this.
Seems if the campground water pressure is high and you don't use any flow reducer this can happen.
It also can happen when hooked up to campground water that has high pressure and you also turn on the water pump which may make the one way valve stay open in the pump because the campground water pressure is higher than the pumps.
My solution was to install this one way valve in line.
This was installed a few years ago and I have not had it fail yet.
Everything works as normal and all you need to do is cut the line and insert it without any fitting.
Link to Grainger $5.80 but I suspect you can find it cheaper.
https://www.grainger.com/product/1DA...180626182021:s
See attached documents and pictures.
