Old 05-27-2020, 08:33 PM   #21
NXR
NXR's Avatar
The total thickness of the two pieces of plastic is maybe 1/8" so aluminum pop rivets likely are the best option. Thanks for the suggestion.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 05-27-2020, 09:07 PM   #22
vasnipe's Avatar
Black Permatex
I can attest to the black Permatex sealant getting everywhere and refusing efforts to remove it. We used that sealant in the engineroom of my first ship, the USS Bagley, FF-1069. We used that goo on the lube oil systems to seal and prevent leaks and the only thing we found to cut that stuff was the JP-5 fuel (jet fuel) we had for our helicopter. Forget rubber / vinyl gloves, they weren't available to us engineers in 1985.
My sympathies, sir and good luck with it staying put.
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 05-29-2020, 03:33 PM   #23
NXR
NXR's Avatar
As long as they stay attached, we have a winner!
The water stream is about 8" to 10" behind the side mirrors so it's not even close.
Ray
ID:	230174   Click image for larger version
ID:	230175   Click image for larger version
Old 06-12-2020, 07:02 AM   #24
A note on applying silicone adhesives.
Use a wet finger. Keep a small plastic cup with you and dip your finger as you smooth the silicone. Water allows your finger to slide over the silicone, not stick, and it does NOT affect the performance of the cured silicone. Silicone uses water/moister to cure.
Now, you don't want to entrap water in the silicone so don't go overboard.
Central Texas
2000 Bloomer Toy Hauler
2000 FLHP
1958 DW
djglover7 is offline   Reply With Quote
Old 06-12-2020, 08:38 AM   #25
NXR
NXR's Avatar
Thanks, I did not know that.
I did find a second use for that messy black Permatex. The caulking that is used where the black paint is present is just painted black and the paint is flaking off in many places. I smeared some of the black Permatex using a gloved finger along the caulk line and so far it's staying on.
That size tube I linked to was enough to install all four gutter spouts with a very small amount left over so I think I'll buy a second tube for caulk covering.
Ray
georgetown
