Old 03-31-2022, 09:35 AM   #1
Keyless entry for 2021 GT 5 34H5
I have been looking at adding keyless entry to my coach. I am looking for suggestions on what make and model you have installed. Was it an easy install or did it require modifications? I知 wanting a simple and direct replacement. Thanks,
DaBull2 is offline   Reply With Quote
Old 03-31-2022, 03:22 PM   #2
KRMann's Avatar
I have installed a keyless entry and helped a buddy of mine install the same lock from RV Lock. I have listed the site below. Been super happy with so far. Can use key, keypad and comes with a key fob. Fairly easy to install but does take some tweaking to install. I had file down (used a dremel tool) just a little of the bottom of the lock hole. Maybe a 1/16th of inch give or take little. Had also adjust the strike plate a little. So nothing major. Fore sure get the extra sticker that goes around the opening to cover up any missing paint. Was installed on 2021-22 GT7 36D7 and 36K7. Here a few pics of the install.
https://www.rvlock.com/?gclid=CjwKCA...hoCh6EQAvD_BwE
ID:	270834   Click image for larger version
ID:	270835   Click image for larger version
ID:	270836   Click image for larger version
Kevin Riley
2022 Georgetown GT7 36D7 Proud Owner
BBQ champion, Reef Tank owner, Bee Hive owner, Traveler
KRMann is offline   Reply With Quote
Old 03-31-2022, 03:57 PM   #3
NevadaMiniLite's Avatar
I also instaled RV Lock on my 2019 Mini Lite 2109S. Just make sure you get the all metal one as I had read of dissatisfaction with the standard ones which are plastic. Mine took all of 10 min to install with no modifications whatsoever. A neighor installed a lock from Latchit and is also happy with his.
https://www.latchit.org/
Camping: Eat till you're tired....sleep till you're hungry....
2021 GMC 1500 Sierra Elevation 3.0 Duramax Diesel
NevadaMiniLite is offline   Reply With Quote
Old 03-31-2022, 04:45 PM   #4
rk06382's Avatar
I also installed RVLOCK on FR3 door. I also installed RVLOCK cabinet locks keyed alike. Now the same key that opens the door opens my 12 basement locks. I also got extra spare keys. I put a spare key on my car key ring.
To get a good discount JOIN RVLOCK VIP EMAIL LIST & Get exclusive access to deals at RVLock.
Memorial Day usually is 30% off.
P.S. Latchit does not have a Class A/C door lock.
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 04-01-2022, 02:52 PM   #5
Paul & Dianne
Installed an RVLock on our 5er right after we got the camper. Fit with no mods at all and works great. We never use anything other than the keypad - haven't heard any "Where are the camper keys?!" in over two years now!
2019 Rockwood 8299BS
2019 F350 Lariat 6.7 CC SRW
ThruHiker is offline   Reply With Quote
Old 04-02-2022, 11:39 PM   #6
Thanks for the replies. Sounds like RVLock is the way to go. Think I値l wait till Memorial Day and try to catch it on sale. Appreciate the info.
Old 04-04-2022, 02:16 PM   #7
Can't get mine to program
Marc G is offline   Reply With Quote
Old 05-26-2022, 01:36 PM   #8
rk06382's Avatar
Exclamation RVLock is having a Memorial Day 30% off sale
RVLock is having a Memorial Day 30% off sale.
Robert
Old 05-27-2022, 06:22 PM   #9
Anyone found a Keyless Lock for Vertical style door handle (2021 GT5 31L5)
Our 2021 Georgetown GT5 31L5 has a door handle that is about 7.5" high and 5.5" wide. I haven't been able to locate a Keyless entry lock for it (Nothing available from RVLock). Wondering if anyone else has been able to find one.
Mike_W is offline   Reply With Quote
Old 05-27-2022, 07:20 PM   #10
Senior Member - Retired
CA Fisherman's Avatar
Can you determine who makes the door handle?
What is the distance between the inside edge of the door itself and the lefthand side of the door handle? It appears to be a significant distance compared to other door handles.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is online now   Reply With Quote
Old 05-28-2022, 09:20 PM   #11
Follow up on vertical style door handle (2021 Georgetown GT5 31L5)
The door lock has Global Link's "G" logo on it, but I haven't been able to find anything like it on their web site. I took it apart to see if I there was a part number inside, but no luck. Just www.rvlocksandmore.com and their phone number. There is a 2 1/2" setback from the edge of the door to the edge of the handle. Searching the web the only thing that seems similar is the TriMark 030-0900. Their outside handle is different, but the lock internals and the inside handle look similar, and it seems to have a similar size cutout. Looks like I've got an odd-ball lock unfortunately, although it works fine. If anyone has any ideas on how to fit a keyless entry I'd appreciate it!
ID:	274108   Click image for larger version
ID:	274109   Click image for larger version
ID:	274110   Click image for larger version
_________________________________
2021 Forest River Georgetown GT5 31L5
2020 Jeep Wrangler Toad
Mike & Denise
Old 05-29-2022, 09:28 AM   #12
NXR
NXR's Avatar
Thanks. That's a lot different than the Bauer paddle lock on our 2020 GT5.
Does the key have any kind of logo on it? That's how we figured out ours was a Bauer.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 05-29-2022, 10:44 AM   #13
Originally Posted by rk06382 View Post
And just yesterday I ordered storage door locks keyed alike to my RV door lock.
No more 751 keys that everyone with an RV has....
Old 06-20-2022, 01:10 AM   #14
Finally installed the RVLock on our 34H5
Waited and got the Memorial Day pricing (30% off). Liked other痴 experiences, I had to slightly enlarge the hole. Very easy to do with drill and small grinding wheel. Handle installed very easily, but I had to adjust strike plate very slightly to get deadbolt to operate smoothly. Had no problems programming door and remote. Thanks for the recommendation to use RVLock.
Old 06-20-2022, 09:31 AM   #15
My locks installed with no modification. Took me approx 30 mins for all of them. They are so much smoother than the chap 751's. This is a highly recommended mod IMO.
Old 02-04-2023, 09:27 PM   #16
Did you ever find a lock that would work for your door?
Will this one fit?
https://www.rvlock.com/collections/c...a-c-motorhomes
Matt
mlkendy is offline   Reply With Quote
