This is our second motorhome with LCI Leveling system (our first was an 2015 FR3, new we have a 2019 Georgetown 378XL). My levels are not level, so I am doing manual. Does anyone remember how to recalibrate the LCI system (obviously on a very level surface)?
LEVEL ZERO POINT CALIBRATION
Before auto-leveling features are available, the Level Zero point must be set.
This is the point to which the system will return when an auto leveling cycle is initiated.
To set the zero point (controller module must be fully secured in production intent location), first run a manual leveling sequence to get the vehicle to the desired level point.
Then activate the Level Zero point configuration mode.
This mode is enabled by performing the following sequence:
1. Turn panel off. Then turn panel on.
2. Perform the following: -Press the FRONT switch 5 times. -Press the REAR switch 5 times.
3. At this point all LED outputs will blink, and the buzzer will be off.
4. You are now in IDLE mode ready to set Zero Point.
5. Press the RETRACT ALL switch 3 times to set the Zero Point.
