Old 07-24-2016, 03:58 PM   #1
swamprat26's Avatar
Lippert hydraulic question
I have 2015 360XL. I noticed and oil spot on driveway. Found that my clear hydraulic fluid tank was wet. Cleaned it really good and cycled my stabilizer jacks s couple of times. Appeared to be leaking out of breather cap and the yellow plug on side of tank. The yellow plug on side of tank had a rubber gasket and it was cracked. The breather cap sponge was soaked in fluid and it was spitting out the breather cap. I couldn't find the same gasket as on the plug but used a oring of the right size. Looked in the owners manual and it says to fill to 1/4" below fill neck. I did but fluid is above the plug on side of tank. Can anyone explain if I'm doing something wrong? Not sure what the side plug is for. Right now tank is dry and keeping an eye on it. Thanks in advance
swamprat26 is offline   Reply With Quote
Old 07-24-2016, 04:06 PM   #2
Witch Doctor's Avatar
You have to check the level that your talking about with all jacks up on level ground, then it's 1/4 down. DO NOT fill the reservoir when the jacks are down. You will over fill it.. .
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-24-2016, 04:12 PM   #3
swamprat26's Avatar
I'm with you on that. Just trying to figure out what the side plug is for
Old 07-24-2016, 04:55 PM   #4
I will take a look, I have never noticed one on mine, might be a breather tube so it can't be sucked down to a vacuum. MAYBE...
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-24-2016, 04:56 PM   #5
swamprat26's Avatar
That is what the top fill plug is.
Old 07-24-2016, 08:05 PM   #6
ron377ts's Avatar
Some reservoir tanks have fill on top, some on side, like mine, no cap on top. I have to use 12 point socket and long extension with swivel to reach it. Then a funnel with tubing to fill. Then duct tape fill cap to socket to screw back in. Pita but works.
Ron & Joanne
Bella The chihuahua
2014 Georgetown XL 377
2007 Jeep Liberty
ron377ts is offline   Reply With Quote
hydraulic
