Old 09-18-2020, 08:42 AM   #1
Looking for the fan resistor
I have an ol 1999 Georgetown on the F53 chassis. The fan only works on high so I know it's the resistor but I can't find anywhere. I've searched for a schematic for the coach with no luck it seems to be to old.
Strech is offline   Reply With Quote
Old 09-18-2020, 09:05 AM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. You may have to go to the chassis manual to find a schematic coach schematics are usually nonexistent.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-18-2020, 09:10 AM   #3
bubbles's Avatar
Check this link. The unit is a little newer than yours but may be applicable. It is a saga. Check post #32.
https://www.forestriverforums.com/fo...an-216096.html
Old 09-18-2020, 10:26 AM   #4
On Ford products the fan resistor is almost always mounted in the plenum right after the fan/blower. All that's visible is a multi-wire connector and a couple screws that hold it in place.
I used to drive Ford company vehicles and for some reason their fan resistors are a frequent replacement item. On my personal vehicles (non-Ford) I don't recall ever having to replace one.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-18-2020, 10:34 AM   #5
bubbles's Avatar
And on my 2012 GT it is inside the MH on the copilot side. However; a recent issue on a 2004 GT revealed that finding the resistor was quite a task and it was mounted in the engine compartment under the hood, hidden and not where expected.
Old 09-18-2020, 11:17 AM   #6
I learned early on to look for the blower and when I found that I then traced the plenum until I found the resistor. I knew it had to be close as the resistor needed cooling air. My Van's and Trucks had it under the hood and my sedans had it above the passenger foot area. Sometimes behind the glove box.
2004 Nissan Titan
Old 09-18-2020, 11:34 AM   #7
Admin may want to move this thread out of the Ford Transit subforum to one thatís more appropriate.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 09-18-2020, 12:24 PM   #8
Welcome to the forum
X2 what Titan Mike said. It's close to the blower motor.
ard58 is offline   Reply With Quote
Old 09-18-2020, 09:14 PM   #9
Looks like it's on the outside of the firewall. I chased the wires from the dash and the fan motor and goes through the firewall to the front. I'll start cutting away at the foam and see what I find.
Old 09-19-2020, 07:42 AM   #10
Ford resistor
I had a 2000 and it was located under a panel on the bottom of the blower housing, couldn't really see it without a mirror, mostly felt for it.
Ratchethead is offline   Reply With Quote
fan
